10 years agoHelp needed
Hi all,
I am trying to implement a 32 bit RISC processor on a Cyclone II FPGA. I'm using quartus 13.0 sp1 tool. I have coded a single stage of the pipeline so far. I have pasted the code below. The errors I have been getting are at lines 5&6 Error (12002): Port "IF_out" does not exist in macrofunction "d1" Error (12002): Port "RR_in" does not exist in macrofunction "d1" Error (12002): Port "IF_out" does not exist in macrofunction "i1" Error (12002): Port "pc_fetch" does not exist in macrofunction "i1" module risc32(pc_fetch,clk); input clk; input [31:0] pc_fetch; reg[31:0] IF_out; IF_decode i1 (.pc_fetch(in),.IF_out(out)); d_flip_flop d1 (.IF_out(d),.RR_in(q),.clk(clk)); endmodule module d_flip_flop(d,q,clk); input d,clk; output reg q; always@(posedge clk) q<=d; endmodule module IF_decode(in,out); input[31:0] in; output reg[31:0] out; reg [4:0] opcode; wire [3:0]op_ext; wire[22:0]arg; wire [1:0]width; wire [3:0] rd_reg0_num, rd_reg1l_num, rd_reg2_num; wire [9:0]ofs; wire [2:0]shift; wire[7:0]k; wire[4:0]k_shift; always@(in, opcode) begin case(in[4:0]) 5'b11101: out[4:0] = opcode; 5'b11110: out[4:0]= opcode; 5'b00000: out[4:0]=opcode; 5'b0xx01: out[4:0]=opcode; 5'b01110: out[4:0]=opcode; default: out[31:0] = 32'bz; endcase end endmodule1 Reply
the . name refers to the port name on the module, not the local varaible. Plus RR_in isnt declared in any of your code.
