10 years agoHelp needed in VHDL Testbench
Hi all, I have written the testbench file in such a manner that I need to perform updowncounting and downcounting based on the value of dir_s. But the problem is, when I execute the code, the di...
10 years agoThis will be because you have the same assertion error if sel_s is '0' or '1' - so I assume it's going to happen on every clock cycle that enable_i is set.
