10 years agoHelp needed in VHDL Testbench
Hi all, I have written the testbench file in such a manner that I need to perform updowncounting and downcounting based on the value of dir_s. But the problem is, when I execute the code, the di...
10 years agoHello,
I needed to design a glitch rejection module in VHDL and I have written the testbench accordingly only. I don't have the source module but I have the design which is as follows: http://www.alteraforum.com/forum/attachment.php?attachmentid=12702&stc=1 . Thetestbench is as follows:stim_proc:process
begin
wait for 10 ns;
reset_n_i <= '1';
wait for 15 ns;
enable_i <= '1';
phi_e_i <= "101010101111010101101010101101010101";
thresh_i <= "11111111";
wait for 100 ns;
phi_e_i <= "111010101101010101010101010101010101";
thresh_i <= "00010110";
wait for 1 ms;
reset_n_i <= '0';
wait for 1 ms;
reset_n_i <= '1';
wait for 1 ms;
enable_i <= '0';
wait for 1 ms;
enable_i <= '1';
wait for 1 ms;
assert False report "End simulation!" severity Failure;
end process;
delay_rst_s <= reset_n_i after 1 ns;
p_check_outp: process(delay_rst_s, clk_128meg_i)
begin
if (delay_rst_s = '0') then
sel_s <= '0';
old_phi_e_s <= (others => '0');
assert phi_e_gr_o = "000000000000000000000000000000000000" report "Output not set to default value when reset_n_i= 0" severity error;
elsif (clk_128meg_i'event and clk_128meg_i = '0')then
if (enable_i = '1') then
old_phi_e_s <= phi_e_i;
new_thresh_s <= std_logic_vector("0000000000000000000000000000" & thresh_i);
if (sel_s = '1') then
assert phi_e_gr_o = old_phi_e_s report "Wrong output: phi_e_gr_o should be equal to old phi_e_i" severity error;
elsif (sel_s = '0') then
assert phi_e_gr_o = phi_e_i report "Wrong output: phi_e_gr_o should be equal to phi_e_i" severity error;
end if;
if (abs(signed(phi_e_i) - signed(old_phi_e_s)) >= to_integer(unsigned(new_thresh_s))) then
sel_s <= '1';
elsif (abs(signed(phi_e_i) - signed(old_phi_e_s)) < to_integer(unsigned(new_thresh_s))) then
sel_s <= '0';
end if;
else
sel_s <= '0';
assert phi_e_gr_o = "000000000000000000000000000000000000" report " Output not set to default value when enable_i= 0" severity error;
end if;
end if;
end process; First, old_phi_e_s should be updated with the phi_e_i only in the rising edge. I don't know how to do this?? What I need to do is , I need to check for the condition if (abs(signed(phi_e_i) - signed(old_phi_e_s)) >= to_integer(unsigned(new_thresh_s))) then, phi_e_gr_o = old_phi_e_s , else phi_e_gr_o = phi_e_i. But it is not doing so. I am getting the errors "Wrong output: phi_e_gr_o should be equal to old phi_e_i" and "Wrong output: phi_e_gr_o should be equal to phi_e_i". Please help me to solve this issue. Thanks in advance.
