10 years agoHelp needed in VHDL Testbench
Hi all, I have written the testbench file in such a manner that I need to perform updowncounting and downcounting based on the value of dir_s. But the problem is, when I execute the code, the di...
10 years ago --- Quote Start --- I am using std_logic_vector and I think so the type is working well. --- Quote End --- std_logic_vector is not meant to represent arithmetic values, the types unsigned and signed are meant to do that. Unless you are using non-standard VHDL packages (like std_logic_unsigned/signed), if you are using std_logic_vector, then using >< or = will always fail if there is a missmatch in vector length. Instead of posting just a extract without the libraries for reference, it can be hard to understand the whole picture. Post the whole code so we can see the code in context.
