8 years agoHelp multiplier vhdl
Hi everyone!
I've some problems with a design, I have to Design an algorithmic state machine to implement a parallel series multiplier for eight-bit numbers encoded in SM (Sign-Magnitude). The multiplying is in a register with parallel output and the multiplier in a shift register of length m with serial output, the first bit to be the least significant. Each bit of multiplier, in his turn, multiplies by multiplying all, so that with operations multiplication is performed. I've the problem with the shift register with serial output, because I don´t know how to do it!! I'm learning VHDL right now, and I've never work with this hardware description language. Please if anyone can help me, I'd be very grateful. Thank you!!13 Replies
Im feeling pretty generous today. I hate seeing overly complicated case statements.
I think the following code does what you're trying to do:library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.all; entity prueba2 is port ( A : in std_logic_vector( (7 downto 0); B : in unsigned (7 downto 0); inicio : in std_logic; clk : in std_logic; reset : in std_logic; q : out unsigned (2 downto 0); resultado : out unsigned (15 downto 0) ); end prueba2; architecture behavioral of prueba2 is signal cuenta : unsigned(2 downto 0); signal y : unsigned(15 downto 0); begin multi : process (clk, reset) begin if reset = '1' then y <= (others => '0'); elsif rising_edge(clk) then if inicio = '1' then cuenta <= cuenta + 1; end if; if A /= x"00" then if A( to_integer(cuenta) ) = '1' then Y <= Y + ( resize(B, y'length)*(2**to_integer(cuenta)) ); end if; end if; end if; end process; q <= cuenta; resultado <= y; end architecture; - Altera_Forum
--- Quote Start --- Im feeling pretty generous today. I hate seeing overly complicated case statements. I think the following code does what you're trying to do:
--- Quote End --- well Tricky that might work but is too tricky for beginner, after all I can just say y = a*b I assume it is exercise that gets more and more compact under pressure...greatlibrary IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.all; entity prueba2 is port ( A : in unsigned (7 downto 0); B : in unsigned (7 downto 0); inicio : in std_logic; clk : in std_logic; reset : in std_logic; q : out unsigned (2 downto 0); resultado : out unsigned (15 downto 0) ); end prueba2; architecture behavioral of prueba2 is signal cuenta : unsigned(2 downto 0); signal y : unsigned(15 downto 0); begin multi : process (A, clk, reset) begin if reset = '1' then y <= (others => '0'); elsif rising_edge(clk) then if inicio = '1' then cuenta <= cuenta + 1; end if; if B /= x"00" then Y <= Y + ( resize(B, 15)*(2**to_integer(cuenta)) ); end if; end if; end process; q <= cuenta; resultado <= y; end architecture; - Altera_Forum
--- Quote Start --- well Tricky that might work but is too tricky for beginner, after all I can just say y = a*b I assume it is exercise that gets more and more compact under pressure...great --- Quote End --- Thank you kaz and Tricky, finally before I read your answers I have solved it in the way that kaz as told me. So I've understood it very well. Thank you so much for the help!!!!
