9 years agohelp in sintax for various inputs to single internal signal vector binary and decimal
hello,,, i have a problem,,
i need read 8 inputs from a digital encoder position d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic, each with (0 or 1 state). but my problem is convert these inputs to a single signal : std_logic_vector(7 downto 0) in a internal signal in the (binary) in the order MSB is d8. then after this vector created to other single output (deci : out std_logic) in one data in decimal, of 0 to 255 Which is its equivalent. any idea that help me in a simple code sintax6 Replies
--- Quote Start --- hello,,, i have a problem,, i need read 8 inputs from a digital encoder position d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic, each with (0 or 1 state). but my problem is convert these inputs to a single signal : std_logic_vector(7 downto 0) in a internal signal in the (binary) in the order MSB is d8. then after this vector created to other single output (deci : out std_logic) in one data in decimal, of 0 to 255 Which is its equivalent. any idea that help me in a simple code sintax --- Quote End --- Internal_signal <= d8 & d7 & d6 & d5 & d4 & d3 & d2 & d1; this concatenation, and it has no cost on resource. - Altera_Forum
--- Quote Start --- Internal_signal <= d8 & d7 & d6 & d5 & d4 & d3 & d2 & d1; this concatenation, and it has no cost on resource. --- Quote End --- Ok thank you and convert this vector of 8 bits to decimal? - Altera_Forum
--- Quote Start --- Ok thank you and convert this vector of 8 bits to decimal? --- Quote End --- dout <= to_integer(signed(interna_data)); it needs library numeric_std - Altera_Forum
--- Quote Start --- dout <= to_integer(signed(interna_data)); it needs library numeric_std --- Quote End --- ok,, in my code when compile, generate multiple output pins, not a single pin "deci" why? library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity joystick is port ( d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic; deci : out integer range 0 to 255) ; end joystick; architecture lectura of joystick is signal val_bin : std_logic_vector(7 downto 0); begin val_bin <= d8 & d7 & d6 & d5 & d4 & d3 & d2 & d1; deci <= to_integer(signed(val_bin)); end lectura; i can save this output in one only value for send these after data to a serial COM for using in a program in PC? my code generate various output pins. - Altera_Forum
Ultimately, your integer deci will have 8 bits, and hence 8 output pins.
If you need to send it to a PC over Serial (RS232 I assume) you will need to serialise these bits - ie. send one at a time. RS232 has a protocol you must follow - and there are many examples out there on the internet. - Altera_Forum
Thank you, i decide my data, leave it in one internal signal of 8 bits, now read about UART examples.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity joystick is port (d1,d2,d3,d4,d5,d6,d7,d8 : in std_logic); --deci : out integer range 0 to 255 end joystick; architecture lectura of joystick is signal val_bin : std_logic_vector(7 downto 0); signal deci : integer range 0 to 255; begin val_bin <= d8 & d7 & d6 & d5 & d4 & d3 & d2 & d1; deci <= to_integer(unsigned(val_bin)); end lectura;
