13 years ago
Help importing C in SystemVerilog
I'm trying to call C routines in SystemVerilog code using DPI and run into problems. I'm using the free Modelsim edition.
There's a simple example in the Altera Modelsim user manual that i'm trying to compile using MinGW for gcc.
The dll is probably compiled correctly and nm path/name.dll shows the function c_test() I'm trying to export to Modelsim.
Also Modelsim locates it correctly (cause when it doesn't it produces an error message).
But the C function basically does nothing at runtime, it produces no output. When I chank c_task() to return an integer in the output argument I get a 0 and not the integer;
No errors are generated by mingw or modelsim !
Code and process from the modelsim manual below. I only removed the exporting of verilog_task() (replaced it with a printf inside c_task) for simplicity.
Any help appreciated. Thanks.
hello_c.c:# include "svdpi.h"# include "dpiheader.h"
int c_task(int i, int *o)
printf("Hello from c_task()\n");
verilog_task(i, o); /* Call back into Verilog */
*o = i;
return(0); /* Return success (required by tasks) */
hello.v:
module hello_top;
int ret;
export "DPI-C" task verilog_task;
task verilog_task(input int i, output int o);# 10;
$display("Hello from verilog_task()");
endtask
import "DPI-C" context task c_task(input int i, output int o);
initial
begin
c_task(1, ret); // Call the c task named 'c_task()'
end
endmodule
Compile the Verilog code:
% vlib work
% vlog -sv -dpiheader dpiheader.h hello.v
Compile the DPI code for the Solaris operating system:
% gcc -c -I<install_dir>/include hello_c.c
% gcc -shared -Bsymbolic -o hello_c.so hello_c.o
Simulate the design:
% vsim -c -sv_lib hello_c hello_top -do "run -all; quit -f"# Loading work.hello_c# Loading ./hello_c.so
VSIM 1> run -all# Hello from c_task()# Hello from verilog_task()
