11 years agolibrary IEEE;
use IEEE.STD_LOGIC_1164.all; ENTITY sirisha IS port ( temp :in std_logic_vector(6 downto 0); CLK :in std_logic; enable :in std_logic; day , night :out std_logic; disp :out std_logic_vector(2 downto 0) ); end sirisha; ARCHITECTURE structure of sirisha IS signal temp :std_logic_vector(6 downto 0); signal CLK :std_logic; signal enable :std_logic; signal day,night :std_logic; signal disp :std_logic_vector(2 downto 0); constant TCLKH_C :time:=5ns; constant TCLKL_C :time:=TCLKH_C; constant TCLKL_C :time:=(TCLKH_C + TCLKL_C); constant TRDELAY_C :time:=TCLKL_C; constant TRHOLD_C :time:=1ns; component sirisha port ( temp :in std_logic_vector(6 downto 0); CLK :in std_logic; enable :in std_logic; day , night :out std_logic; disp :out std_logic_vector(2 downto 0) ); end component; cur_st_process (CLK,enable) begin if (enable='0') then cur_st <= start; else if (CLK'event and CLK='1') then cur_st<=next_st; end if; end process cur_st_pr; nxt_st_process (cur_st,temp) --next state comb. circuit begin if(temp>"1000110")then nxt_st<= day; else if (temp<"0110010") then nxt_st<=night; else nxt_st<=cur_st; end if; end process nxt_st_pr; reg_pr : process (enable,CLK) begin if (enable='0') then day <='0'; night <='0'; disp <="000"; else day <='1'; night <='1'; disp< ="001"; end if; end process reg_pr; begin (temp=>temp,CLK=>CLK,enable=>enable,day=>day,night=>night,disp=>disp); end structure; thanks alot will i av to build one myself or buy one or does it come with the de2 board?.pls help me check d code it is still giving me errors.i want the leds to come on if the if statement of nxt_st_process (cur_st,temp) is satisfied but it still doesnt work
