11 years ago
help! .FPGA based led lighting where d lights come on at night and goes off at day
Good day guys!...I'm totally new to hardware implementation using FPGA but I can do this using microcontrollers.I have d altera de2 board and i have been having a hard time learning d vhdl code to implement this...pls help this newbie out,it will go a long way in encouraging me if I can implement it on the de2 board.
    The problems I'm facing include:
    -how do i interface d ldr(sensor) with the d de2 board
    -how do I convert d analog input from d sensor to digital form in other to generate my output from an external led
    -will I use d expansion header to connect d external ldr circuit
    - what pins will I assign in my code so the de2 board will be able to recognise my analog input and my output(external led)..pls help!
    Show us what you've done so far, and let us know what you're having problems with
    --- Quote Start ---
    --- Quote End ---
    Thankz I have bn able to do smthng.I was able to turn on the led using switch 'swo' on the board using this code LIBRARY IEEE;USE IEEE.std_logic _1164.all;ENTITY streetlight IS PORT (D, resetn,clock: IN STD_LOGIC; Q :OUT STD_LOGIC);END flipflop;ARCHITECTURE Behaviour of streetlight IS BEGIN PROCESS (Clock,resetn)BEGINIF Clock 'EVENT AND CLOCK='1' THENIF resetn='0' THEN Q
    LIBRARY IEEE;
    Q :OUT STD_LOGIC);
    END flipflop;
    BEGIN
    BEGIN
    IF resetn='0' THEN
    Q<='0';
    ELSE
    Q<=D;
    END IF;
    END IF;
    END PROCESS;
    END BEHAVIOR;
    I have done this and I have assigned pin to produce d output on an led on d de2 board.when i push d switch down d led comes on when i push it up d led goes off.but now I want to use an external ldr to generate analog input that will b converted into digital form whose output will turn on an external led.that is when it is dark d ldr will generate input signal that will turn on d led and when if is day d ldr will generate signal to turn off d led.
    Pls put me through
    library IEEE;
    use IEEE.STD_LOGIC_1164.all;
    ENTITY sirisha IS
    port ( temp :in std_logic_vector(6 downto 0);
    CLK :in std_logic;
    enable :in std_logic;
    day , night :out std_logic;
    disp :out std_logic_vector(2 downto 0)
    end sirisha;
    ARCHITECTURE structure of sirisha IS
    signal temp :std_logic_vector(6 downto 0);
    signal CLK :std_logic;
    signal enable :std_logic;
    signal day,night :std_logic;
    signal disp :std_logic_vector(2 downto 0);
    constant TCLKH_C :time:=5ns;
    constant TCLKL_C :time:=TCLKH_C;
    constant TCLKL_C :time:=(TCLKH_C + TCLKL_C);
    constant TRDELAY_C :time:=TCLKL_C;
    constant TRHOLD_C :time:=1ns;
    component sirisha
    CLK :in std_logic;
    end component;
    cur_st_process (CLK,enable)
    begin
    if (enable='0') then
    cur_st <= start;
    else if (CLK'event and CLK='1') then
    cur_st<=next_st;
    end if;
    end process cur_st_pr;
    nxt_st_process (cur_st,temp) --next state comb. circuit
    begin
    if(temp>"1000110")then
    nxt_st<= day;
    else if (temp<"0110010") then
    nxt_st<=night;
    else
    nxt_st<=cur_st;
    end if;
    end process nxt_st_pr;
    reg_pr : process (enable,CLK)
    begin
    day <='0';
    night <='0';
    disp <="000";
    else
    day <='1';
    night <='1';
    disp< ="001";
    end if;
    end process reg_pr;
    begin
    (temp=>temp,CLK=>CLK,enable=>enable,day=>day,night=>night,disp=>disp);
    end structure;
    thanks alot will i av to build one myself or buy one or does it come with the de2 board?.pls help me check d code it is still giving me errors.i want the leds to come on if the if statement of nxt_st_process (cur_st,temp) is satisfied but it still doesnt work
    Im not familiar with the DE2, but the features dont seem to specify an ADC. You may need to connect one to one of the expansion headers.
    What errors are you getting with the code? do you have a test bench?
