16 years agoHelp: about simulation waveform
Hi, may i know is there a way to convert the simulation waveform into .txt format because i using quartus to generate test sequence and the output is in .vwf and i need to apply the test sequence into HOPE simulator which is using .txt format. So, now i'm collecting the test sequence which is in .vwf into the .txt format by manually typing it.
Please let me know if there is a way to convert it, THX...
