Altera_ForumHonored Contributor16 years agoHelp: about simulation waveform Hi, may i know is there a way to convert the simulation waveform into .txt format because i using quartus to generate test sequence and the output is in .vwf and i need to apply the test sequence int...Show More
Altera_ForumHonored Contributor16 years agoWithout seeing the code, your problem doesnt make alot a sense.
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
