11 years ago
Hello world example make errors
I got follow errors when I typed in the "make -f Makefile“
This is the hellowrold example for OpenCL SDK 13.1.
I think I have set up the correct paths for altera's library. But I'm using the board remotely, so I am not sure if some other libs are missing. Please advise.
make <- 2:58PM
/usr/lib/x86_64-redhat-linux5E/lib64/../lib64/crt1.o: In function `_start':
(.text+0x12): undefined reference to `__libc_csu_fini'
(.text+0x19): undefined reference to `__libc_csu_init'
/opt/Altera/13.1/hld/linux64/lib/libstdc++.so: undefined reference to `__tls_get_addr'
/opt/Altera/13.1/hld/linux64/lib/libalteracl.so: undefined reference to `pthread_create'
/opt/Altera/13.1/hld/linux64/lib/libalteracl.so: undefined reference to `pthread_detach'
collect2: ld returned 1 exit status
make: *** [bin/hello_world] Error 1
    --- Quote Start ---
    --- Quote End ---
    I trimmed off the parts I can not help you with.
    The undefined references above can be fixed with a "-lpthread" added to the link command.
    Gary.
    Thanks! Now I am one step closer!
    --- Quote Start ---
    Gary.
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    if you Google the text shown in red above (three seperate searches), you will find that others (non-OpenCL) have had this problem, and how they fixed it.
    Basically the linker can't find the libraries - not knowing your configuration I can't recommend a direct fix.
    I tried to reply yesterday, but that post never made it to the board.
    Gary.
    Thank you, Gary. I googled and manually linked the libs and it works.
    Cheers.
    -Rae
    --- Quote Start ---
    Gary.
    --- Quote End ---
