HongLiang
3 years agoHi
May I clarify with you below items:
Q1. Which Quartus version you are using?
22.4
Q2. Which OPN you intend to use?
there are 2 OPN we will use
AGFB027R31C2E1V AGIB027R31B1I1V
Q3. May i know which design example variant and settings you want to generate?
we will need HDMI TX /RX SDI TX/RX DP TX/RX
I try to use op1(intel recommand)
step1. create a whole new project for AGFB027R31
step2. call the HDMI IP -->set the hdmi in TX and AXIS mode to generate
setp3. generate the example IP
but I still see the example target ID is not the same as the project OPN
HongLiang
3 years agoHi
maybe you guys can try to find a way or step to create the AGFB027R31C2E1V HDMI example
