HDMI example an not change the device in V22.4 for aglixe FPGA
Hi Liang Hong,
Thank you for your patience.
You need to select the OPN before generating an example design.
There are 3 ways you can use to select OPN number:
Option 1. Select OPN in "New Project Wizard" (Recommended)
New Project Wizard
Option 2. Select OPN in Project Navigator by double clicking on the OPN
Changing device via double clicking OPN
Do note if you change by option 2 with an IP already generated, in some cases, Quartus will require to perform device migration before compilation. This sometimes may lead to unintentional error due to different device, structure and settings.
Option 3. By checking the "Change Target Device" checkbox
IP Parameter Editor
For Option 3, you need to click view-> Device Family in order to select your desired device.
View dropdown list
Hope this answers your question.
May I clarify with you below items:
Q1. Which Quartus version you are using?
Q2. Which OPN you intend to use?
Q3. May i know which design example variant and settings you want to generate?
Thank you.
ZulsyafiqH_Intel
- HongLiang3 years ago
Hi
22.4
there are 2 OPN we will use
AGFB027R31C2E1V AGIB027R31B1I1V
we will need HDMI TX /RX SDI TX/RX DP TX/RX
I try to use op1(intel recommand)
step1. create a whole new project for AGFB027R31
step2. call the HDMI IP -->set the hdmi in TX and AXIS mode to generate
setp3. generate the example IP
but I still see the example target ID is not the same as the project OPN
Hi
maybe you guys can try to find a way or step to create the AGFB027R31C2E1V HDMI example
