Have both versions of Intel SoC EDS Professional and Standard but Pro version won't launch?
I have the Intel SoC EDS Standard version running for an older board I have, the Terasic DE1-SoC which has the Cyclone V on board. I also have downloaded the SoC EDS Pro Version so I can compile designs to use HPS resources on a Terasic S10 Apollo which has the Stratix 10. I have no issues launching the SoC EDS Command. bat for the standard version, But when I go to launch the Pro version it opens and terminates quickly.
Are both versions essentially the same ? If not, is there a conflict with one causing the pro version to terminate?
I have the same versions, 20.1 for both.
- aikeu
Hi Embeddedesigner,
SoC EDS is a discontinued product, which is no longer supported referrring to the link:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS#Configure_FPGA
Anyway from the examples it is working with 20.1 pro version. I think it should not have any problem. I think can check with the setup from the linke if there is any difference from your setup.
Aik Eu
- RHobb
Ok thank you,
The Intel Arm DS Studio webpage does state:
"Arm DS for Intel® SoC FPGA works in conjunction with the Intel® SoC FPGA Embedded Development Suite (SoC EDS)."
https://www.intel.com/content/www/us/en/software/programmable/soc-eds/arm-ds.html
Must be out of date. I still havn't gotten the legacy version to work yet. But I'll transition over to the Arm DS studio for future HPS development. One thing I did also note was that if a user bought a development board through Terasic or another approved vendor, you have to buy the software for $995. Otherwise if you buy the dev board straight through Intel, the fee gets waived.
- aikeu
- aikeu
- aikeu
Hi Embeddedesigner,
I am closing the thread for now as we do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
Aik Eu
