JacekCi's avatar
JacekCi
5 years ago
Has anyone succeeded running Questa Starter with license file?
HI all,
After some days when it was not possible to generate license file for Questa Starter it is finally possible to do it. But unfortunately the license file that is sent over the email does not allow running Questa Starter.
After trying to run Questa there is an error message saying:"Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem."
If license file (fixed) is generated with host Id, the lmutil lmstat says "Error getting status: No SERVER lines in license file. (-13,66)"
Is there ANYONE that can help on this? The documentation is quite poor, because for example in some places it says that Questa starte does not require license file (which is not true).
Does Intel actually care about customers who want to use this version of the software??
