JacekCi
4 years agoHas anyone succeeded running Questa Starter with license file?
HI all,
After some days when it was not possible to generate license file for Questa Starter it is finally possible to do it. But unfortunately the license file that is sent over the email does not...
Yannis
4 years agoI confirm that with the help of the employees, my case was solved. I was instructed to the correct System Variable name:
"LM_LICENSE_FILE" which points to the dat file I was sent from Intel by email (I was using a wrong variable name).
To make this entry, you may perform a windows Search for "System Variables" and then click on "Edit the System Environment Variables" and then click "Environment Variables". Be aware that you must add the entry in System variables, not user variables.
(if you print "system v" instead, you can see it).
OH1
4 years agoI simply never receive the email, despite all indications I should
Intel has been no help
