Has anyone managed to program a .jic into an ISSI 128Mbit config program P/N IS25LP128
Hi CChal,
I haven’t program a .jic into an ISSI 128Mbit.
However, in Quartus 19.1 version, we have a new feature which is we can defined our own flash device.
1. Go to File > Convert Programming File
2. On Programming file type, Select JTAG Indirect Configuration File (.jic)
3. Select “ … ” button (on the left of the Mode option)
4. Configuration Device windows pop-up
In this Configuration Device, you can define your own flash device and Quartus Programmer able to program withour error.
I think you can try to have a look at this new feature.
Unfortunately, there are two known issues regarding to this user-defined feature. Below are the workaround for these issues.
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/error-210026---file--user-directory---file-name--jic-is-corrupte.html
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-my-user-defined-flash-device-database-in-custom-configu.html
I hope this will help.
