10 years ago
handling two dimensional array using vhdl
i have a two dimensional array in a text file. i want to read it from the text file and write it in another text file as a two dimensional array. i have tried using the code given below. but it writes only one column. how to write all the columns.
library std;
use std.textio.all; --include package textio.vhd
--entity declaration
entity filehandle is
end filehandle;
--architecture definition
architecture Behavioral of filehandle is
--period of clock,bit for indicating end of file.
signal clock,endoffile : bit := '0';
--data read from the file.
signal dataread : real;
--data to be saved into the output file.
signal datatosave : real;
--line number of the file read or written.
signal linenumber : integer:=1;
begin
clock <= not (clock) after 1 ns; --clock with time period 2 ns
--read process
reading :
process
file infile : text is in "bit8.txt"; --declare input file
variable inline : line; --line number declaration
variable dataread1 : real;
begin
wait until clock = '1' and clock'event;
if (not endfile(infile)) then --checking the "END OF FILE" is not reached.
readline(infile, inline); --reading a line from the file.
--reading the data from the line and putting it in a real type variable.
read(inline, dataread1);
dataread <=dataread1; --put the value available in variable in a signal.
else
endoffile <='1'; --set signal to tell end of file read file is reached.
end if;
end process reading;
--write process
writing :
process
file outfile : text is out "bit8_inv.txt"; --declare output file
variable outline : line; --line number declaration
begin
wait until clock = '0' and clock'event;
if(endoffile='0') then --if the file end is not reached.
--write(linenumber,value(real type),justified(side),field(width),digits(natural));
write(outline, dataread, right, 16, 12);
-- write line to external file.
writeline(outfile, outline);
linenumber <= linenumber + 1;
else
null;
end if;
end process writing;
end Behavioral;
1 Reply
    Your code has no mention of a line length, so there is no way to know how many values to write onto each line.
    The write process also writes out every single value. You need to save the writeline() procedure until you have a complete line to write.
