Brad thank you very much... I changed the second ff to work with en (the new clk)
but I can't manage to define internal signal as global clk
signal clk_2 : std_logic;
begin
process(reset,clk1)
begin
if reset='1' then
counter<="0000000000000000000000001";
-- counter<="01";
clk_2<='0';
elsif rising_edge(clk1) then
-- if (conv_integer(counter) mod 2=0) then
if (counter="1011111010111100001000000") then
clk_2<=not(clk_2);
else
counter<=counter+1;
end if;
end if;
(the program changes 50 MHz->2 Hz)
I can't detect this signal in the Assignment editor, only the signals in entity...
tenx
ari
