HHami3
6 years agoGlobal assignment being deleted/changed when using same source in multiple VHDL libraries.
Hi there, I have an entity in a file which is compiled into two different VHDL libraries. I also have two different packages with the same name, for each library which are input into the entity. Whe...
HHami3
6 years agoYes thank you, you may close the case.
