8 years agoGetting 'Timing requirements not met' as critical warning
Hi, I have created a design and would like to compile the design in order to create a binary file for the CPLD. However when I try to compile the design, it outputs a warning saying that the timing r...
Saravana1987
2 years agoHi Sir
When I add the .sdc file with all requirements such as create_clock and clock derivativity I got the same issue timing requirements not met. I got pll with 210MHz , 17ns and another 17ns with 5ns phase difference and the input clock is 50 MHz, will you please guide me in this issue.
T.S.Saravana Kumar
T.S.Saravana Kumar
sstrell
2 years agoProbably should create a new topic here in the forum and include your .sdc file and what you're seeing in the timing analyzer. This is a 6 year old thread.
