8 years agoGetting 'Timing requirements not met' as critical warning
Hi, I have created a design and would like to compile the design in order to create a binary file for the CPLD. However when I try to compile the design, it outputs a warning saying that the timing r...
8 years agoTCWORLD, thanks for the recommendation. I appreciate it. I have modified the code a clock pulse instead of generating a clock in logic and the timing requirement warning has gone.
I should probably create a new thread about this, but I will ask it here anyway: Do I need to purchase a Quartus Prime license in order to flash to MAX-V CPLD or can I use the Quartus Lite version? I only need to generate a programmable file and not debugging features etc.
