8 years agoGetting 'Timing requirements not met' as critical warning
Hi, I have created a design and would like to compile the design in order to create a binary file for the CPLD. However when I try to compile the design, it outputs a warning saying that the timing r...
8 years agoHave you created your own timing constraints? if you dont, it will try and make it meet a 1GHz clock, which will never meet timing.
You need to provide your own timing constraints.
