16 years agogetting error
i m doing a project to display real time video on a monitor connected to vga.i wrote some code but getting error while compilation top entity is pots,other file are attach
cyclone ii-v-9sp2
Error: Port "clk27_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_data_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_hs_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "td_vs_to_the_tv_in" does not exist in macrofunction "nios" Error: Port "vga_b_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_blank_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_clk_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_g_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_hs_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_r_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_sync_from_the_vga" does not exist in macrofunction "nios" Error: Port "vga_vs_from_the_vga" does not exist in macrofunction "nios"
