12 years ago --- Quote Start --- Hi, Thanks for your reply, but as you answer : I can only say "I don't want the QII place the logic automatically". I just want to know if there is a way to get the LAB Number, Name and Position. --- Quote End --- I really don't know why you stuck to want place logic manually. However, you can find the logic resource coordinate system from QII easily, as attached image shows. Actually, you'll find it's very difficult to mach between your high level description language (such as VHDL) and the low level logic unit (such as LE. You need deeply into the netlist to do the position lock. It's a very large work.
