KAkyo
7 years agoGeneration of STP file for SignalTap
Hello, There is a locking issue in my application on FPGA board and I want to debug my application. When doing research, I found SignalTap is used to follow the signals in the application. I played ...
JOHI
Contributor
7 years agoHello,
If you start using signaltap logic analyser it generates .stp as a result of your configuraton in signaltap. (make a configuration and save it)
You will have trouble finding some signals in the node list, to solve this you can define the attribute "keep" in your code, then some invisible nodes will become visible with their orignial name.
Example:
-- declare --
attribute keep: boolean;
signal reset_p : std_logic:='0';
signal done : std_logic:='0';
signal enable : std_logic:='0';
attribute keep of reset_p : signal is true;
attribute keep of done : signal is true;
attribute keep of enable : signal is true;For your problem you might consider using modelsim and write a simulation bench.
This enables you to simulate your design. This approach can be much more productive than signaltap.
On the other hand: are you 100% sure that ram is the issue with Quartus?
Of course it depends on the size of your design, but Quartus runs well in 8GB ram for small designs.
Johi.
