10 years agoGenerating ALTPLL with the Command Line
I'd like to generate an ALTPLL block (see zip attachment) by means of a command-line tool. I'd like to say something along the lines of: "C:\altera\15.0\quartus\sopc_builder\bin\ip-generate" -...
10 years agoI found an even better solution: Quartus models the PLL and RAM megafunctions (IP blocks) as parametrised HDL modules, so you can instantiate it directly. I'm auto-generating (for example) the Verilog code:
// For the MAX 10 (and Cyclone IV and below):
altpll# (
.operation_mode("NO_COMPENSATION"),
.inclk0_input_frequency(20000), // 50 MHz
.clk0_multiply_by(1),
.clk0_divide_by (5),
.clk1_multiply_by( 1),
.clk1_divide_by (10),
.clk2_multiply_by( 1),
.clk2_divide_by (20),
.clk3_multiply_by( 1),
.clk3_divide_by (40),
.clk4_multiply_by( 1),
.clk4_divide_by (80),
.width_clock(5)
)PLL(
.inclk ({1'b0, Clk}),
.clk (Clk_Out),
.locked(Locked)
// For the Cyclone V (and any other higher-end modern FPGA):
altera_pll# (
.fractional_vco_multiplier("false"),
.reference_clock_frequency("50 MHz"),
.operation_mode("direct"),
.number_of_clocks(5),
.output_clock_frequency0("10 MHz"),
.output_clock_frequency1("5 MHz"),
.output_clock_frequency2("2.5 MHz"),
.output_clock_frequency3("1.25 MHz"),
.output_clock_frequency4("0.625 MHz"),
.pll_type("General"),
.pll_subtype("General")
)PLL(
.rst (Reset),
.outclk(Clk_Out),
.locked(Locked),
.refclk(Clk)
