14 years ago --- Quote Start --- For simple digital design, verification of the logic in ALTERA DE0 is done. --- Quote End --- What is done? Simulation, synthesis or both? --- Quote Start --- I've written VHDL code for square wave generation using DAC(Digital to Analog Converter). What all the components and files required to check the output on Cathode Required Oscilloscope. --- Quote End --- You can program the FPGA and look at the signal with an oscilloscope. If you have a sampling oscilloscope with more bits and wider bandwidth than your DAC, then you can capture a block of samples, and analyze it to see if your DAC meets specifications. --- Quote Start --- How about generation of User constrained file in ALTERA. Please let me know the implementation part in ALTERA DE0 kit. --- Quote End --- You would need to constrain the clock(s) and clock-to-output delays to the DAC. The timing requirements that the FPGA must meet are defined in the DAC datasheet. However, if you are using a DAC on the DE0, then Terasic should have an example constraints file. Cheers, Dave
