18 years agoI'm not sure why you're not seeing the initialization occur. It's almost as if modelsim isn't reading in that mem_init line.
An SR is a service request, i.e. it goes to an apps engineer who will work with you on resolving the problem(as opposed to a forum, which is based on the kindness of strangers, i.e. help will only go so far). You may want to create a simple test case, such as a design with a single initialized RAM, the produced .vo file, the testbench that reads from a location, and the .do file to run Modelsim and show that 0s are coming out. That way the apps engineer should be able to quickly recreate what you're seeing. (You might be able to put the example up here, too, but again you're relying on someone to voluntarily try it out.) Good luck.
