18 years agoAre you sure the synthesis is reading in the .hex files? Look at the Fitter Report -> Resource Section -> Ram Summary under the MIF(Memory Initialization File, but it will also show .hex files) for that particular ROM. If it says None, it was never read in. I believe(but am not positive) that once it gets read in, the initialization should be in the post-synthesis netlist and you shouldn't have to re-read any initialization files.
