--- Quote Start ---
hi,
i am using a Cyclone II FPGA and i want to generate a vqm file by the Quartus II Compiler. When i compile my design , sometimes a ASCII text file is created, and sometimes a binary file. what should i do in order to create a ASCII text file,instead of a binary file?
--- Quote End ---
Hi suplina,
choose : Assignments -> Settings -> Compilation Process Settings ->
"Save a node-level netlist of the entire design into a persistent source file"
Quartus will create a new directory "atom_netlist". You will find the vqm file in this
directory.
Kind regards
GPK
