17 years ago --- Quote Start --- But I couldn't find a tool to easily dump a memory module's data. --- Quote End --- I use a small "core" with a LAIC connected to a serial interface. I use pseudo-DS to get out of the fpga and connect to another aveal board with a differential OP input to access the ram. If you have a eval board with a large ram, you can also program retriggered shots or pipe line read out. Thus it is mostly possible to interface to nearly all plants. I already had been able to install such a battery powered eval board into a plant, let it remotely aquire (no persons allowed during operation due to radio beam) and got it out of the plant after operation to read it out in my office. The was no other way to scan the bus behaviour-:p
