9 years agogate lev sim not working as expected
hello everybody im quite new in developing for FPGA. I have started wih DE0-nano board. im learning just programming an easy FSM that performs elementary operations. i have followed the tut...
9 years agofollowing the code that works in RTL simulation but not in gate level simulation.
IN particular, in gate level sim, the counter is not increasing and the state jumps directly into '11' that is not correct. Thanks for the help
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.all;
ENTITY somma_FSM IS
GENERIC
WAIT_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"00";
WORK_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"01";
END_STATE :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"11"
PORT
ingressoA : IN STD_LOGIC;
ingressoB : IN STD_LOGIC;
inizia : IN STD_LOGIC;
resetn :IN STD_LOGIC;
clock : IN STD_LOGIC;
finito : OUT STD_LOGIC;
somma : OUT STD_LOGIC;
resto : OUT STD_LOGIC
END somma_FSM;
ARCHITECTURE somma_FSM_architecture OF somma_FSM IS
SIGNAL current_state :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"00";
SIGNAL next_state :STD_LOGIC_VECTOR(1 DOWNTO 0) := B"00";
SIGNAL counter :STD_LOGIC_VECTOR(2 DOWNTO 0) := B"000";
SIGNAL resto_in :STD_LOGIC := '0';
SIGNAL resto_out :STD_LOGIC := '0';
BEGIN
PROCESS(inizia, current_state, counter)
BEGIN
CASE(current_state) IS
WHEN B"00" =>
IF (inizia = '1') THEN
next_state <= B"01";
ELSE
next_state <= B"00";
END IF;
WHEN B"01" =>
IF (counter = B"111") THEN
next_state <= B"11";
-- finito <= '1';
END IF;
WHEN B"11" =>
WHEN OTHERS =>
END CASE;
END PROCESS;
PROCESS(clock)
BEGIN
IF (resetn = '0') THEN
current_state <= WAIT_STATE;
counter <= (OTHERS => '0');
ELSE IF ((clock'EVENT) AND (clock = '0')) THEN
current_state <= next_state;
IF (current_state = B"00") THEN
ELSE IF (current_state = B"01") THEN
counter <= counter + '1';
resto_in <= resto_out;
END IF;
END IF;
END IF;
END IF;
END PROCESS;
somma <= ingressoA XOR ingressoB XOR resto_in;
resto_out <= (ingressoA AND ingressoB) OR (ingressoA AND resto_in) OR (ingressoB AND resto_in);
resto <= resto_out;
finito <= '1' WHEN current_state =B"11";
END somma_FSM_architecture;
