14 years ago
gate delays
I need to implement a boolean function using nand and nor gates ,
and the gates should have 20ns delays. How should I change the following verilog code?
and how could I simulate the results?
is it possible to manually adjust the gate delays?
module nand ( a,b,c);
input a,b;
output c;
nand(c,a,b);
endmodule
does# 20 nand(c,a,b) work?
1 Reply
    First of all, that code is verilog, not VHDL.
    Secondly, you'll need to register it to get a 20ns delay (with 50Mhz clock)
