13 years ago --- Quote Start --- Ok, maybe my post has a lack of information... The decision has to be taken at each clock cicle because those Integers change at every clock cicle, there is no problem in take a little delay but would not like to take it if I don't have to. I'm not familiar with the use of a RAM in the FPGA... How to pipeline this? I'm not familiar with that either... Thanks --- Quote End --- If your data is slow then a practical way is to run at 256 times the data rate then streamline the data and apply the algorithm: -- clked process if data < data_min then data_min <= data; end if; at the end of stream the value will be in data_min You need also to take care of signed/unsigned issues. edit: from where do you get 256 data at same time? Certainly not from pins. If they are generated internal to fpga then I will assume they might be streamlined already and you can then insert above algorithm at that point.
