--- Quote Start ---
That error probably came from elsewhere. How about posting the full code, not just a snippet.
--- Quote End ---
ok....this is the full code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.seven_segment_pkg.all;
entity Switch7Segment is
port (
SW: in std_logic_vector(9 downto 0);
HEX0: out std_logic_vector(6 downto 0);
HEX1: out std_logic_vector(6 downto 0);
HEX2: out std_logic_vector(6 downto 0);
HEX3: out std_logic_vector(6 downto 0);
KEY: in std_logic_vector(3 downto 0);
CLOCK_50: IN STD_LOGIC
end entity Switch7Segment;
architecture behavior of Switch7Segment is
signal segments1: std_logic_vector(13 downto 0);
signal segments2: std_logic_vector(13 downto 0);
signal segmentsR: std_logic_vector(27 downto 0);
signal input1: integer;
signal input2: integer;
signal result: unsigned;
signal temp: integer;
begin
input1 <= to_integer(unsigned(SW(4 downto 0)));
input2 <= to_integer(unsigned(SW(9 downto 5)));
segments1 <= unsigned_to_seven_segment(value => unsigned(SW(4 downto 0)), number_of_digits => 2, value_is_bcd => false);
segments2 <= unsigned_to_seven_segment(value => unsigned(SW(9 downto 5)), number_of_digits => 2, value_is_bcd => false);
HEX1 <= segments1(13 downto 7);
HEX0 <= segments1(6 downto 0);
HEX3 <= segments2(13 downto 7);
HEX2 <= segments2(6 downto 0);
PROCESS(CLOCK_50)
BEGIN
IF (CLOCK_50' EVENT AND CLOCK_50='1' AND KEY(0)='1') THEN
temp<=input1+input2;
result<=to_unsigned(integer(temp), result'length);
segmentsR <= unsigned_to_seven_segment(value => unsigned(result), number_of_digits =>2, value_is_bcd =>false);
HEX1 <= segmentsR(13 downto 7);
HEX0 <= segmentsR(6 downto 0);
END IF;
end Process;
end;
Package
library ieee;
package seven_segment_pkg is
-- Return a std_logic_vector ready for driving a number of 7-segment displays.
function unsigned_to_seven_segment(value: unsigned; number_of_digits: integer; value_is_bcd: boolean)
return std_logic_vector;
end;
package body seven_segment_pkg is
function seven_seg_from_bcd_digit(bcd_digit: std_logic_vector(3 downto 0)) return std_logic_vector is
begin
case bcd_digit is
-- abcdefg
when x"0" => return "1000000";
when x"1" => return "1111001";
when x"2" => return "0100100";
when x"3" => return "0110000";
when x"4" => return "0011001";
when x"5" => return "0010010";
when x"6" => return "0000010";
when x"7" => return "1111000";
when x"8" => return "0000000";
when x"9" => return "0010000";
when x"a" => return "0001000";
when x"b" => return "0000011";
when x"c" => return "1000110";
when x"d" => return "0100001";
when x"e" => return "0000110";
when x"f" => return "1110001";
when others => return "0000000";
end case;
end;
-- Return a vector ready for driving a series of 7-segment displays.
value: unsigned;
-- Number of 7-segment displays (determines output vector width: W = 7*N)
-- When true, treat the input value as a BCD number where every 4 bits hold one
-- digit from 0 to A. When false, treat the input number as an unsigned integer.
variable segments: std_logic_vector(number_of_digits*7-1 downto 0);
variable bcd_quotient: unsigned(value'range);
variable bcd_remainder: unsigned(3 downto 0);
begin
if value_is_bcd then
for i in 0 to number_of_digits-1 loop
segments(i*7+6 downto i*7) := seven_seg_from_bcd_digit(
std_logic_vector(value(i*4+3 downto i*4))
end loop;
else
bcd_quotient := value;
bcd_remainder := resize(bcd_quotient mod 10, 4);
bcd_quotient := bcd_quotient / 10;
std_logic_vector(bcd_remainder)
end loop;
end if;
return segments;
end;
end;
