good question.
component is meant to be direct definition of a design modul with its inputs/outputs and internal functionality. function( also has inputs/outputs and internal functionality but these are not meant to be direct module definition but rather a piece of user code to be inserted when that function is called up. it could due to the way HDL evolved (component from symbol era, function of programming language) - Altera_Forum
--- Quote Start --- Hi When we use “ function” and where is its exact usage? what is the difference between it and “component”? if it is possible explain it by examples. Thank you --- Quote End --- A component is basically an entity. And of course an entity is something which encapsulates your logic design. It has inputs, outputs, internal signals and whatever logic you can imagine. A function is a bit of logic which executes in delta time, and is commonly used to implement code which gets reused. The various conversions you find in numeric_std, such as to_unsigned(), are examples of functions. Unlike its cousin the procedure, a function may not include any delay or wait mechanisms.
