9 years agoFull compulation for large IO pins
Hi I would like to perform full compilation for component (not the Top Level) that has large IO pins. Im looking at over thousands bits in output bits. But I need to know the total LEs and Fmax...
9 years ago --- Quote Start --- Without seeing the code, I cannot really say alot. But long compiliation times for idividual modules (eg >30 mins) is likely a problem in the code and the easiest way to kill it is to have a large ram that gets inferred as registers instead of Ram blocks because the behaviour is incorrect. Can you post your code? --- Quote End --- Basically the top module is as such: module KC(clk, reset, in, out); input clk; input reset; input [575:0] in; output [511:0] out; wire [1599:0] r0, r1, r2, r3, r4, r5, r6, r7, r8, r9, r10,r11; wire [1599:0] r12,r13,r14,r15,r16,r17,r18,r19,r20,r21,r22,r23; assign out = r23[1599:1599-511]; mKC round0 ( clk, reset, 8'h01, {in, 1024'b0 } , r0); mKC round1 ( clk, reset, 8'h32, r0, r1); mKC round2 ( clk, reset, 8'hba, r1, r2); . . . . . . . --basically there are 23 identical portmap as above endmodule and each of the mKC module contains several logical expression with output is registered.
