m_kumar
6 years agoFT232h as synchronoud FIFO
Hi
so this the first time i'm integrating with FT232h as synchronous FIFO with MAX10 . To send large amount of data to host pc from fpga fifo memory (with different input width and output width wit...
- 5 years ago
I believe @monte refer to this link:
https://numato.com/kb/ftdi-asynchronous-fifo-interfacing-with-telesto/
RichardT_altera
6 years agoI found a similar forum case and technical notes that may help to clarify your questions.
Hope it helps.
https://community.intel.com/t5/Programmable-Devices/FTDI-FT2232H-Sync-FIFO-FPGA/td-p/131049
https://www.ftdichip.com/Support/Documents/TechnicalNotes/TN_167_FIFO_Basics.pdf
m_kumar
6 years agoThank you.
i will update result soon.
- RichardT_altera5 years ago
How was the result? Do you need further assistance?
- m_kumar5 years ago
still not completed the work. problem is i am using 8bit bidirectional data bus to transmit and receive data. During receive i'm receiving data correctly in 8bit data bus but when i send data to PC data bus was going to don't care condition.
