13 years agoSuggestion: next time wrap your code using the# button for the forum so the spacing is preserved.
Just looking at the code, I do see one problem. Assuming in[11] is an asynchronous clock when compared to clk, the assignment of in_count to out_count is unstable. I suggest trying to search for information regarding crossing clock domains. I also can't say that I'm thrilled with the double use of posedge in your second process. If in[] is an internally registered signal, I also agree with FvM that doing this can cause timing issues with Timequest (unless you setup your SDC correctly).
