9 years agoFrequency division for use in an 8x1 multiplexer
Greetings everyone, I want to design an 8x1 Multiplexing system. Starting with a frequency of (50 MHz) as the first input to the multiplexer; I want to divide this frequency by (2,3,...,8). What can ...
9 years agoYou can do in VHDL the same as the block diagram, and vice versa. So creating clock enables is a good idea.
Yes you can modify the VHDL after you generate it from block diagram, but you must remember to remove the block from the project and add the VHDL to the project. You cannot covert VHDL to block diagram.
