9 years agoFPGA(Opencl) code work well in emulator mode, but can't finish run on the FPGA
Hello: When I run my FPGA(OpenCL) code in emulator mode, the result is right; but after I create hardware configuration file and run on the FPGA, the code is blocked and can't fin...
9 years ago --- Quote Start --- 1) Is there any error output? 2) What hardware are you using? 3) Did you use a reference design? --- Quote End --- --- Quote Start --- Thanks for your reply! I want to printf some informations, but the informations are not display.Do you know why?Does it means my code did not reach there before blocked? My code as belows: # pragma OPENCL_EXTENSION cl_altera_channels : enable // Channel declarations channel float DATA_IN __attribute__((depth(8))); channel float DATA_OUT __attribute__((depth(8))); channel float CONV1_WEIGHTS __attribute__((depth(8))); channel float CONV1_BIAS __attribute__((depth(8))); //num_channel = num_pre_feature_maps!!!!! __kernel void data_in(int num_pre_feature_maps, int num_feature_maps, __global const float *restrict input) { printf("data in\n"); int global_idx = get_global_id(0); int global_idy = get_global_id(1); int global_offset = global_idy * get_local_size(0) + global_idx; printf("data in global_idx=%d global_idy=%d\n", global_idx, global_idy); //Read data float data = input[global_offset]; for(int i = 0; i < num_feature_maps; ++i){ for(int j = 0; j < num_pre_feature_maps; ++j){ printf("channel read datanum_feature_map=%d global_idx=%d global_idy=%d\n", i, global_idx, global_idy); write_channel_altera(DATA_IN, data); } } } __kernel void weights_bias_in(__global const float *restrict weights, __global const float *restrict bias) { printf("here\n"); int global_idx = get_global_id(0); int global_idy = get_global_id(1); //Read Weights write_channel_altera(CONV1_WEIGHTS, weights[global_idy * KERNEL_SIZE * KERNEL_SIZE + global_idx]); //Read Bias if(global_idx == 0){ printf("gidx=%d gidy=%d\n", global_idx, global_idy); write_channel_altera(CONV1_BIAS, bias[global_idy]); } } __kernel void conv(int map_size, int num_pre_feature_maps, int num_feature_maps, int relu_on) { printf("conv start\n"); float res_buf[28 * INPUT_SIZE]; float weights_buf[KERNEL_SIZE * KERNEL_SIZE]; float bias_buf[MAX_NUM_FEATURE_MAPS]; float rows[4 * INPUT_SIZE + 5]; //load bias for(int i = 0; i < num_feature_maps; ++i){ printf("i=%d\n", i); bias_buf = read_channel_altera(conv1_bias);
//printf("bias data=%f\n", bias_buf); } //printf("End of load bias\n"); //int input_size = map_size + KERNEL_SIZE - 1; for(int num_feature_map = 0; num_feature_map < num_feature_maps; ++num_feature_map){ for(int i = 0; i < KERNEL_SIZE * KERNEL_SIZE; ++i){ weights_buf = read_channel_altera(conv1_weights);
printf("i=%d w=%f\n", i, weights_buf); } for(int i = 0; i < 1024; ++i){ for(int j = (4 * INPUT_SIZE + 4); j >0; --j){ res_buf[j] = res_buf[j - 1]; } res_buf[0] = read_channel_altera(DATA_IN); } //test for(int i = 0; i < map_size; ++i){ for(int j = 0; j < map_size; ++j){ double res = res_buf[i * INPUT_SIZE + j] + weights_buf[num_feature_map] + bias_buf[num_feature_map]; if(relu_on){ res = (int)res > 0.0f ? (int)res : 0.0f; } printf("write channel i=%d j=%d res=%f\n", i, j, res); write_channel_altera(DATA_OUT, res); } } } } __kernel void data_out(int num_feature_maps, __global float *restrict output) { printf("data out start\n"); int local_idx = get_local_id(0); int local_idy = get_local_id(1); int global_idx = get_global_id(0); int global_idy = get_global_id(1); printf("data out global_idx=%d global_idy=%d\n", global_idx, global_idy); for(int i = 0; i < num_feature_maps; ++i){ printf("data out num_feature_map=%d global_idx=%d global_idy=%d\n", i, global_idx, global_idy); float data = read_channel_altera(DATA_OUT); //float data = 1; int global_offset = global_idy * get_local_size(0) + global_idx; output[global_offset] = data; output += get_global_size(1) * get_global_size(1); } } Can you find any problem?? Thank you! --- Quote End --- It only can printf out information in the "weights_bias_in" kernel.
