FPGA OpenCL installation
I am running Quartus Pro 21.3 with DE10-Pro Stratix 10 BSP from 20.3. According to the installation guide, you need to set QUARTUS_ROOTDIR_OVERRIDE to quartus 20.3 path in order for you to use OpenCL 21.3 with an older BSP. But, when I did that, both the flashing and the compilation still used 21.3 and the compilation failed indicating that it was using an older TCP/IP core with quartus. Does 20.3 need to be in the path? What does QUARTUS_ROOTDIR_OVERRIDE do? Seems to me that it's useless and you just need to set Quartus 20.3 in the path while you have OpenCL pointing to 21.3. What is the correct way to do this?
QG
- BoonBengT_Altera
Moderator
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Mind if I ask in which OS are you using? Assuming windows, are the environment variable set at the command prompt or manually in the system property?
Is the QUARTUS_ROOTDIR_OVERRIDE showing up when you echo the path or environment variables? Does the aocl install command run successfully?
Hope to hear from you soon.Best Wishes
BB - BoonBengT_Altera
Moderator
Good day, just following up on the previous clarification.
By any chances did you managed to look into the it?Best Wishes
Moderator
Greetings, as we do not receive any further clarification on what is provided, we would assume challenge are resolved. Hence thread will no longer be monitored. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
