Quantitative_Finance
4 years agoFPGA OpenCL installation
I am running Quartus Pro 21.3 with DE10-Pro Stratix 10 BSP from 20.3. According to the installation guide, you need to set QUARTUS_ROOTDIR_OVERRIDE to quartus 20.3 path in order for you to use OpenC...
BoonBengT_Altera
Moderator
4 years agoThank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Mind if I ask in which OS are you using? Assuming windows, are the environment variable set at the command prompt or manually in the system property?
Is the QUARTUS_ROOTDIR_OVERRIDE showing up when you echo the path or environment variables? Does the aocl install command run successfully?
Hope to hear from you soon.
Best Wishes
BB
