StefanoC's avatar
StefanoC
3 years ago
Fpga not seen
Running latest quartus prime pro and visual studio. I can compile my C code with oneAPI from VS only when the fpga is simulated, otherwise it crashes at runtime. This may be due to not seen fpga I guess. I have two boards attached, one via USB (DE1) surely ok as I see it from quartus (so why the intel compiler crashes? Maybe the USB can't be used as introduced latency?), the PCI (cyclone 10gx) has a green led on but I just installed (brand new) I can't see it in quartus under tools/programmer..
  • Hi @StefanoC,
    Thank you for posting in Intel community forum and hope all is well.
    If I understand the situation correctly you are facing issues on full compilation for oneAPI application?
    Would you be able to share a screenshot/command that you compiled oneAPI code for simulation? (for us to better understand sample application and environment)
    Assuming you are using the full system compilation flow, for that flow it requires a BSP for the hardware/full compilation, and unfortunately DE1 and C10GX are not in the supported hardware for oneAPI.
    You may refer to the below links for BSP details:
    - https://www.intel.com/content/www/us/en/developer/tools/oneapi/fpga.html (For non PAC product, please scroll to the 'Choose an FPGA Platform' section)
    - https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2023-1/fpga-bsps-and-boards.html (For PAC product)
    Hope that clarify.
    Best Wishes
    BB
  • Hi @StefanoC,
    Greetings, just checking in to see if there is any further doubts in regards to this matter.
    Hope your doubts have been clarified.
    Best Wishes
    BB
  • Hi @StefanoC,
    Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
    Best Wishes
    BB
