FPGA Floating License | error missing option file for alterad/mgcld vendor
Hello
Welcome to Intel forum. To narrow down this issue, can you please provide me the latest of the following?
1) Debug.log file
2) Machine OS information
3) Output of “lmutil lmstat –a –c <port>@<address>” server and client
4) license.dat file
FYI, you can find debug.log file at LMTOOLS > path to the debug log file.
You can also reply/attach your file in private message.
Hi there,
thank you for your response. I've tried to narrow down the information you requested, however I think we are both talking about a different LM software. The one we're using is the Flexnet License manager, from Revenera. That lmutils you are referring is a license server within the FPGA software. I tested/opened the various lmtools executables found within different folder under the intelFPGA software. All show that the service is not installed or running, which I can understand since we use the Revenera license manager/server.
So the debug.log file is not present- eventhough I could find the patch within the LMTools application. The directory it points to is empty.
Machine OS = Server 2022 standard | 21h2
See the private message for the requested files.
