11 years agoFormal verification on modelsim (systemverilog)
Hi
I am trying to write a verification environment on the modelsim simulator. My problem is to work the signal driver tasks (BFM) from the sequence driver (generator) when both of them are in the environment level block (agent). ////////// Drivers ////////// class Driver; virtual SVinter SVinter_int; function new (virtual SVinter i); SVinter_int = i; endfunction task clk_drive; input Iclk; SVinter_int.clk = Iclk; endtask endclass ////////// Sequences ///////// class sequenceDrive; task sequences; fork forever begin // # 10 Driver.clk_drive(1'b1); <= this of course don't work // # 10 Driver.clk_drive(1'b0); end join endtask endclass ////////////////////////////// ////// Main environment ////// ////////////////////////////// class environment; virtual SVinter SVinter_int; function new (virtual SVinter i); SVinter_int = i; endfunction Driver Driver_inst; sequenceDrive sequenceDrive; task build_environment; Driver_inst = new(SVinter_int); sequenceDrive = new(); endtask task start_test; sequenceDrive.sequences; endtask Endclass What is the best way to operate the Driver from the sequence drive? And later I'll need to move the data struct from the monitor to the scoreboard. What is the best way to do that? thanksNo RepliesBe the first to reply
