13 years agoforeach in systemverilog
What is wrong with this piece of code? Questa has no problem with it but Quartus does. Quartus has no issues with it if I remove the foreach and replace it with generate statement. al...
13 years agoYes! Of course... Quartus does not compile with foreach statement... I just assumed that it was obvious because all I use Quartus is to compile the code i.e. synthesize and p&r.
Quartus thinks it's a syntax error atleast the error seems to suggest that. Don't remember or have the exact error in front of me. But it doesn't matter any more since Altera's support indicated that "foreach" statement is not supported Quartus 12.0. Quartus 12.0 help seems to indicate all loop constructs are supported.
