You cannout use the IEEE floating library very well in quartus, because your maximum clock speed would be very very slow (maybe 25MHz if you're lucky). The Altera FP cores are pipelined so speeds >300MHz should be possible.
ah ok I m working with 50 MHz frequency clock.
there is an other way to present real number or I must use this FP core with less performance?? thanks - Altera_Forum
use the floating point cores from the megawizard
